View Full Version : Jacuzzi tub main switch.
Debbie Pounders
07-05-2007, 09:26 AM
We had an inspector come out to our home, and he got the Jacuzzi Tub working. But now, the switch on the tub will not come on. I think there may be a disconnection between the master switch and the switch on the tub.
Where is the master switch on the tub? Is it on the pump? I have already tried the breaker switch--did not phase it.
Thank you,
Debbie
jadnashua
07-06-2007, 12:49 PM
If this is an air switch, there is a plastic hose on the back of the switch that might have fallen off.
07-06-2007, 07:41 PM
Your GFCI the tub is plugged into could also have tripped. If so, and it happened because the pump was started, it could indicate an electical problem.
