Removing Old Wax from Under Toilet
Verdeboy
When resetting a toilet, in order to remove the old wax that has adhered to the bottom of it, you need to tip the toilet. This means that all the nasty water in the toilet trap must be removed first or you'll spill it out.
How do you guys deal with this situation? It seems crude to dump it into a bath tub, and usually it's not feasible to carry it outside to dump it. Do you try to dump it into a bucket or what?
Disposable latex gloves, and a sponge will pretty much get all of it. Lots of rags on the floor anyway.
Use an accordian plunger to push out most of the water...wipe out the excess with a rag with surgical gloves on.
Run the rag under scalding water to sterilize.
Less equipment to lug into someone's home along with tools and johnny bolts/ring.
We use a $35 wet vac for removing water from the tank and bowl.
It's much cleaner and quicker.
This way, we don't need to use the customers bath tub or lav.
