View Full Version : Shower Arm Flange for Hacks?
andruesw
07-01-2007, 03:47 AM
I did a reasonable job of cutting and applying tile around my shower arm opening on the wall. Problem is, the shower arm flange that came in the kit doesn't quite cover up my flaws. If I had maybe 1/4 inch additional all around on a flange, I could cover up everything. Is there anyone who makes a shower arm flange a bit wider than the standard?
Take a trip to Low*s and HD and ask, you may find one.
Verdeboy
07-01-2007, 12:03 PM
If you can't find a larger flange, you can simply put a bead of caulk around the flange you have.
Just curious why you didn't tile completely over the shower arm opening, and then use the appropriate size carbide gritted hole saw. (You use a piece of cardboard to make a template of the hole location before you tile).
GrumpyPlumber
07-01-2007, 12:36 PM
Hd carries the bits.
Or..Rotozip works well with ceramic tile.
Verdeboy
07-01-2007, 03:57 PM
I like to use the rotozip tile bit for enlarging holes when nec. But I find it much easier and faster to make the hole with a carbide-tipped hole saw.
GrumpyPlumber
07-01-2007, 06:13 PM
Oh yeah, I keep a rotozip on the truck for shower valves specifically.
All I use it for...then pop on a goof plate after.
