Check Valve?
Foglifter
I recently updated my jet pump. I have low cut in pressure and the cut off is about 25. Any higher setting and I have no pressure at all, then need to reprime and fill the tank again. Yes, the tank seems to empty back to the well.
Should there be some type valve that I didn't replace? There is a piece on the old pump that had a line to the back of the old pressure switch, which the new switch dos not require. Thanks for your help.
