I need a 1 1/4" slip joint 90 degree elbow.
enviroko
Anyone know where I can find one? They are tough to find on the web and Home Depot didn't have them. Thanks
I assumed you are looking for PVC, but regardless of whether it's copper or PVC, go a a real plumbing shop. Box stores typically only handle items that have a fairly rapid turn over. Most plumbing supply houses say the will only sell to licensed plumbers, but for one or two pieces they usually will make a cash sale to anyone. Just don't expect to buy major items.
elbow
A double slip joint elbow is a difficult fitting to keep together. What you need is a 1 1/4" "flush elbow" which has a slip joint on one end and a length of tubing on the other that you cut to fit as necessary. Good plumbing stores have them.
I assume this is for a bath faucet. Many times it's easiest to go from 1 1/4" to 1 1/2" at the pop-up drain using a reducing ferrule. Then use a 1 1/2" p-trap, etc..
