The correct way is to install it after the new floor is installed, anchored through the floor into the subflooring. Less chance of leaking, and a normal wax ring is all that is needed. If you notch the tile for the mounting bolts, you don't need to try to drill afterwards. The flange should sit tight on top of the finished floor.
