View Full Version : Roman Tub Spout Leaking
billrea
06-18-2007, 01:56 PM
Hope someone can point me in the right direction. I have a deck mounted roman tub slide on spout from Moen. Problem is the water supply shank coming up through the deck is to short to pass through the rubber O-ring. Is there anyway to extend the shank without replacing the inverter assembly below the tub?
Any guidance would greatly be appreciated.
Thanks,
Bill
tammoo
02-19-2011, 11:44 AM
Hi Bill,
I was just curious as to whether or not you were able to fix this problem. I am having a similar issue and not quite sure what to do. Any suggestions are very welcomed!
Thank you,
Tammy
