New water main = bathroom trouble
bschafran
Hello - I just had a new sewer main installed to replace Orangeburg pipe. As part of the install, the contractor had to cut and install a new water main . All plumbing fixtures in the house (ranch with basement) are operating at full pressure except for the basement bath. To my best knowledge, the same lines feed a washer/dryer (OK) a rough-plumbed sink connection (no sink but OK pressure upon opening the valves) and exterior garden faucet (OK). In the bath, I have a dribble of water at the sink, shower, and toilet has no water. I have hot water but it dribbles at the same rate as the cold. My first thought was debris in the line, but both hot and cold? Prior to the repair these were all functional. This is probably the first time the sewer and water main have been touched in 30 years. I would appreciate any feedback from the readership. Thanks and have a great day.
Sounds like supply valves may be turned off. Have you checked.... I would also call back the contractor.
What are your supply pipes made of? If they are galvanized, you might have a conversion to something newer in the future. Turning the water on and off, draining it can release all sorts of crud from the insides of the pipe. The tub/shower often have inlet particle screens that could be clogged up. On the vanity sink, take the aereator out and check it; it is probably clogged. Same with the showerhead. You could take the showerhead off and run things...if the flow is good, then you know it is inside of the head.
Got it
Disconnected all fixtures in bathroom, found individual plugs in each one, ran water, all good. I guess this concentrated here since it's the low point of the house. Thanks to all. Saved me $ for sure.
