How to sanitize house plumbing
lardlad
Michigan
We are finally about a week away from a new deep well on our cottage property. We've used a shallow well for 40 years and in the past 15 of those years quit using the water for cooking and drinking due to the color. We never had it tested but in the past had a cartridge filter on it and I recall drinking it as a child.
Anyway, now that we will have a new deep well with good clean water, I'm worried about connecting to the plumbing in the cottage. How can I chlorinate the plumbing, water heater? When they chlorinate the well can I have them pump it through the household plumbing and let it sit for a day or so?
Thanks for your help
One way to sanitize all of the plumbing in the house is to pour several gallons of bleach down the wellhead, and then run all hot and cold water lines until you smell the bleach water coming out of each faucet and spigot.
Let it set in the lines a least 12-24 hours, and then flush all lines until the bleach odor is gone.
Good Luck!
Mike
Several gallons of bleach down the well is WAAAAAAY too much.
The recommendation at the site at the link below is 3 pints of standard household bleach per 100 gallons of water in the well. That is about 150 ft of water in a 4" pipe or hole. See the table at the link.
http://www.water-research.net/shockwelldisinfection.htm
The bleach should be mixed with water about 1 part bleach per 10 parts water so you minimize corrosion risk on the casing and pump, and then pour it into the well allowing 3 pints of bleach per 100 gallons of WATER in the well. Wash down the casing with a few gallons of clear water after you pour in the bleach solution.
Follow the instruction on the site for pumping through the system.
Yes, and I did exactly that just a few months ago as part of finally getting rid of a sulfur odor in our system. However, the check valve in your system will keep anything inside the house from contaminating your new well, and chlorine in your overall plumbing is likely going to cause some oxidation and settling of any iron in your water.
Personally, I would be inclined to first let the well be sanitized and flushed ... then just run all the house faucets (inside and out) for an hour or so and flush the water heater.
Can i put bleach in my house filter to sanitize the water lines?
City water with sewer? If so, probably yes. How will you account for the water heater water diluting the bleach more than the cold?
If you have a well, you might want to sanitize the well and plumbing at the same time. If you have septic, you will want to control how much bleach hits the septic tank. https://terrylove.com/forums/index.php?threads/well-sanitizing-extra-attention-to-4-inch-casing.65845/ is my writeup for sanitizing bottom-feeding wells that have submersible pumps.
