Pump on/off every couple seconds
edgerhaser
My submersible pump turns on/off every couple seconds when water is turned on (water pressure in house is fine). The pressure gauge does not seem to move 55 psi.
I recently went on vacation and turned the power "off" to pump but water softener was "on", so water pressure dropped off
Found problem
I found the problem, a rust hole on side of tank. Hooked up air compressor to tank found leak Thanks for the help. My next purchase is a plastic tank, one of the nice features w/Plactic is bladder can be replaced and buried, Well-Made.
