View Full Version : Proper termination of unused circuit
garyl53
06-14-2007, 02:22 PM
Hi,
I am removing a whole house fan since we have air conditioning and never use the fan. The opening and louvres, although insulated, are letting too much heat and cold transfer and it looks ugly in our main hallway.
What is the proper method to disable the current electrical feed to the fan and to the switch/speed control in the hallway. I am assuming the main feed goes to the fan first and then the speed control wiring comes from the main fan area down to the speed control although I haven't been up there yet.
Any help is appreciated.
Thanks,
Gary
barrybpdx
06-14-2007, 09:40 PM
trace the circuit backwards to the point at which it branches to the fan and switch.
if the circuit doesn't continue on beyond the fan and switch, then undo the hot and neutral wires that branch to the fan and switch and leave them capped in the box.
if there's more stuff past the fan and switch, then just take the switch out of the circuit (cap the hot switch feed in the switch outlet box).
and always turn off the breaker before you start.
note - i'm not an electrician.
jwelectric
06-14-2007, 09:48 PM
i'm not an electrician. None the less it was good advice and the same that I am giving
Cass
06-15-2007, 05:15 AM
If the box cover or box itself ends up with a hole where there was a wire that you removed the hole needs to be covered / plugged properly.
garyl53
06-15-2007, 11:48 AM
Thanks all for the answers.
Gary
Jeff1
06-21-2007, 10:30 AM
I have both A/C and a whole house fan and they complement each other very well. It has saved some $$ going to SCE. If it aint broke...
