View Full Version : How 2 replace glued abs p-trap
bender
02-21-2005, 08:58 PM
Goody, new cabinets, counters, and sinks and I'm doing it myself. The old sink went to an abs p trap and then a little more abs pipe into the wall. The whole assembly is made of small sections that are glued together and won't meet the new sink due to different sized everything. I have a really sharp saw and I can cut thru anything but how do I connect the cut end to something new? It's not like cutting a long run of pipe where you join 2 straight sections by sliding each into a connector. Any cut I make will go thru a glued joint. What's the right strategy? Thanks.
Gary Swart
02-21-2005, 10:56 PM
I'd begin at the wall. Cut out everything between the wall and new sink. Use an ABS male adapter at the wall and work toward the sink with a new metal trap. You don't want a sinkl trap that can't be opened for cleaning anyway.
