Seaneys
Hello,
If I understand it correctly, I need to use barrier pex with my cast iron boiler and radiators. From what I have read, barrier PEX is sensitive to UV and needs to be protected from direct contact with sunlight.
The problem is that I need to run pex across an unprotected basement wall before it goes into the studded walls. The room has a small window at the top (2'x3') that I keep a curtain on... How stringent is the UV requirement? Is there a sheathing that I can buy to protect the PEX?
Thanks,
Steve
Thanks,
Steve
