BS
06-11-2007, 09:04 PM
This is not exactly a remodeling question but the problem is the result of some home improvement.
Eight years ago I replaced my 20-year old roof, stripping everything off the roof sheathing, placing felt, and installing three-tab fiberglass shingles. A couple years later I added a couple bathroom fans and vented them individually through the roof, one on each side of the plumbing vent pipe (2' spacing). Last year, in heavy rain, water leaked into the attic 1 to 2' downslope of the plumbing vent pipe and one of the attic fan vents. I added more roofing cement around the roof penetrations and that seemed to solve the problem -- or so I thought. A couple months ago we had more heavy rain and the leaks returned, and I added more roofing cement. But the leaks continue in heavy rain.
Since the leaks are directly downslope of the roof penetrations, I suspect water is getting under the felt at one or more penetrations and flowing downslope until it finds an entry route through the sheathing. But I can't figure out how that could be happening.
As far as I can tell the shingles are in good shape and I can see no damage. The only thing that appears unusual is that a couple fo the shingles that overlap the sides of the vent pipe flashing don't lie flat on the flashing but stick up a little. I filled these gaps with roofing cement but it made no difference.
Any suggestions?
- Bernie
Any suggestions?
- Bernie
