View Full Version : Water Master drip system that won't stop running
rose821
06-07-2007, 10:10 AM
I recently moved in a house with a Water Master Model #57974 system. I have set all the zones and the sprinklers for the grass which are on one zone work perfectly. However, the drips for the plants will not shut off - water continually runs from them even when I shut off the system completely (at the box - turn to Off). I don't know anything about these systems so any info would be appreciated.
Verdeboy
06-07-2007, 01:27 PM
Find the zone valve for the plants and try to manually shut it off. It is probably in the ground near the plants in a green box. If it won't shut off, you'll have to take the valve apart and clean the diaphragm(s).
rose821
06-07-2007, 03:02 PM
Thanks Eric - appreciate the response. I'll give it a try.
