can you prime a pump from out put hose?
indika
Canada
My prime plug is stuck, Can I prime the pump with the prime hole and prime the input hose separatelsy then connect the whole thing and run, will this prime the pump?
I mean, disconnect the hose that goes into the tank, fill the pump with water from their (instead through the priming hole), fill up the hose from the lake with water, pout it togather, then start the pump
I'm going to disconnect the hose that comes from the lake, at the pump and fill the hose with water, then attache to the pump. Fill the pump using the outlet hose (the one that goes to the tank, then attach that hose to the tank. start the pump.
Will this work?
