Randyj
05-30-2007, 01:07 PM
I'm trying my best to get this job wrapped up. We installed a couple of rather simple Price Pfister shower/tub valves. Everything is by the book. I turned on the hot water side and both (2 tubs) valves in the house had water running out even tho' they were in the off position. I pulled the valve bonnet (the guts of the valve) to check for trash and it is still leaking when I turn on either the hot or the cold supply. Is this normal since these are balancing valves?
Even worse... when the water is on for the tub spout it comes out the shower head.... this is a nightmare! It is completely plumbed with 1/2" CPVC with 1/2" copper to the spouts and shower. I just added a pressure regulator at the water meter which should limit pressure to about 75 psi...but that is not the problem as the water still comes out the shower head even with the single handle control valve barely opened... any ideas? As for the tub spout, it appears to be working perfect.
