View Full Version : Using PVC for Hot Water Drain
chucknewell
02-19-2005, 09:34 PM
What is the concensses for using PVC for the drain line of a dishwasher? I know it can't be used for hot water distribution but it is used for drain lines. I installed a Johnson Tee in the wall of my kitchen instead of a counter top air-gap and plumbed it with PVC, see photo. Afterward I found the photo attached that was done with copper. Does it matter?
Chuck
Gary Swart
02-19-2005, 09:48 PM
PVC is OK for drains, hot or cold. You're set up looks OK to me, but I'm no pro. Likely one of them will respond.
The PVC may not give you any problems, although if a fitting should crack it will create a major repair problem for you. The bigger problem I see is that you have connected the dishwasher directly to the drain pipe. Unless that Johnson fitting has an air gap function that is not visible, that is not a good idea.
chucknewell
02-20-2005, 10:20 AM
Here's some photos of the Johnson Tee. It is an air-gap that replaces the counter-top air gap. The horizontal pipe goes through an exterior wall with the trim piece installed outside.
In that case it would satisfy all but the most rigorous inspector. That inspector might insist on a physical air gap, citing the possibility for algae and other growths to use the interior of the Johnson fitting as a path to enter the dishwasher drain tube. While that is seldom a valid consideration, I have had it quoted to me in similar circumstances.
chucknewell
02-20-2005, 11:29 AM
Yup, the inspector would not approve it! It's the old "letter of the law / spirit of the law" controversy. The Johnson Tee was tested, approved, and carries the UPC symbol. However, the code states that a "listed" air-gap must be installed. The Johnson Tee was the only thing the inventor sold and he couldn't justify spending the $3000+ dollars every year to keep the part "Listed". No listing, No inspector approval. Is it safe? Does it work? Is it UPC approved? . . . Doesn't matter, It's not LISTED! :mad:
Chuck
