eddle6389
02-19-2005, 03:37 PM
Hello,
I am in the process of installing my new Flotec Sewage Ejector Pump. I have an odd angle where my discharge line from my pump ties into my main 4 inch drain line. The builder has a 4" to 2" plug in the cleanout and I am tying in to that point. I can force the 2" lines together, but I don't get a complete fit. Is this OK or can I use a section of flexible pvc to make this connection? The specs on the flex pipe say it is rated to 100psi, but I'm not sure if you can cement it to rigid pvc.
Question # 2 - How far should your vent pipe extend into your sump basin?
Thanks in advance for your help.
John
John
