View Full Version : Running Water and Drain from Slab to Slab
bnoji
05-22-2007, 07:51 AM
I'm looking for some guidance on running water/drain from the house to a detached garage approximately 35ft away. Both are on slab foundations. It seems the easiest place to tie in is the kitchen cold water and drain as they are both above the slab, directly against the back wall and the nearest water/drain to the garage. I've gathered that I'll need to dig a trench 36" deep and run 1/2" K-copper and 3" PVC under the footings of both the house and garage. The copper will be sheathed in 1" PVC where it contacts the slab.
I'm unclear about a few things:
1. How to connect the incoming drain to the existing undersink drain. I've attached a picture of what it looks like under the sink:
http://home.comcast.net/~bnoji/images/undersink.jpg
ETA: The blue valve is for a silcock on the back of the house. I assume I will need a sump to make use of the kitchen drain?
2. The best way to excavate and fish the lines through the fill between the slab and the bottom of the footings.
I considered breaking up a 2'x2' square in each slab, working from the inside and finishing with bag concrete. If there were a way to do it from the outside (and not have to break up the floor) I'm open to suggestions.
I paid a plumber to do an estimate. He said it would be several thousand and if I don't mind the digging I could do it myself in a weekend and save on most of that. I'm comfortable doing all the labor involved, but not the planning/design.
jimbo
05-22-2007, 06:39 PM
Naturally, you cannot connect to the kitchen drain above ground. Round number, you will need about about 9 inches of drop on the drain line as it runs from the outbuilding to the house. You will need to jack into the slab under the kitchen or somewhere to tie that in.
kordts
05-22-2007, 07:40 PM
What fixtures are being installed? That small of pipe and that distance might be a no-no.
bnoji
05-23-2007, 05:59 AM
The only fixture in the garage will be a utility sink.
So you're saying I need to dig 36" on the garage side and approximately 45" on the house side in order to maintain that slope at a proper depth? What drain would I tie into that I would find at that depth?
I was told a pump would allow me to drain a sink from a lower area to a higher area. Maybe something like this: http://www.femyers.com/Products/sse/sse_ed25.html
bnoji
05-23-2007, 08:22 AM
I took a few more pictures this morning and tried to sketch out the existing drain locations in case it may help. Please excuse the embarassing mess in the yard...the house was left to us with "some work" to be done and I'm right in the middle of it all.
I mapped out all the drains in the house:
http://home.comcast.net/~bnoji/images/floorplan.jpg
Looking at garage (from silcock on back wall, directly in front of sink):
http://home.comcast.net/~bnoji/images/at-garage.jpg
Looking at the house:
http://home.comcast.net/~bnoji/images/at-house.jpg
bnoji
05-23-2007, 06:36 PM
It looks like all the drains in the house lead to the bathroom. Unfortunately, the bathroom is the only room in the entire house where I can't break the floor because of the new tile (and it's our only bathroom).
While following the drain lines I noticed that there is no slab under the tub (not just the drain, but the entire tub). Is this normal?
The other issue I'm having is with the slope of the drain. Assuming the main sewer line is 12-16" below the house slab, maintaining a downward slope would require me to go through the footings of both buildings. This opens up a whole new line of questioning....
1. Does the drain line need to be below the frost line as well?
2. Is it acceptable to go through the footings rather than under?
3. For the supply lines to the garage, can I use a conduit bender and torch to make a continuous "L" and avoid the 90 degree joint under the slab?
I have plenty more questions, but I'm not so sure I'll be able to do this the right way. Thanks for the help so far.
Pewterpower
05-23-2007, 07:39 PM
If it's just a utility sink, I'd just run the drain line thru the wall and out onto the ground, or maybe a drain tile.
bnoji
05-23-2007, 08:02 PM
The garage sits in a low spot and I already have some drainage issues. The previous owner never installed gutters on the 20 year old garage (and removed them from the house years ago).
I'm not even sure if I'll be able to excavate for the supply line on the garage end. Last time I tried I made it 30 inches down and my hole started filling quickly through the footings (from the inside out).
Right now I have a hole in the garage wall bridged by a piece of 1/2" copper and a silcock on each side of the wall. When I need water, I roll out a garden hose, connect it to the outer silcock, turn on the outside valves, drain into a 5 gal and carry it up the hill in the background when it's full.
toolaholic
05-23-2007, 10:07 PM
#1 We have no idea how many units are coming in from the garage.
#2 Are You thinking of dumping them into an 1 1/2" waste line??
#3 It's obvious ,by your questions, You are in no way qualified to attempt this job? Suggest You hire a plumbing cont.
bnoji
05-24-2007, 06:47 AM
As I said, the only fixture draining into this is a utility sink in the garage.
Why not? The water being drained is clean (not grey/black) and at a rate far less than an average sink or clothes washer. The question was how and where to do it.
I already stated I was not experienced and that I paid a plumber for an estimate. He told me I could do this myself over a weekend and they would end up charging me several thousand.
Running the supply line is no problem. With a ditch witch, we'll have that done in under 2 hours. I'm really only looking for suggestions on options for running the drain lines because breaking the slab over the drains (bathroom floor) is not an option.
