ginahoy
05-18-2007, 12:30 AM
In my last house, I experienced an occasional but obvious sewer gas smell from at least two of our three toilets. The third one got little use. I did many things to troubleshoot. The smell was definitely coming from inside the bowl.
Both offending toilets had overflowed at one time or another, so I figured dirty water had risen above the fill holes and leaked into the upper rim, leaving deposits on surfaces that never get flushed. I finally ended up taking one of the bowls outside for a thorough cleaning. Among other things, I turned it upside down and filled interior of rim with bleach. After carefully reinstalling the toilet with a new ring, the smell eventually returned. Mystery was never solved.
Shift forward in time. I recently moved into a two-year old house with two toilets. One had a defect and had to be replaced. Since then, I'm certain this one has never overflowed. To my surprise, I've had several instances of a definite sewer gas smell from both toilets. I'm sure it's coming from the bowl because the smell hits you in the face when you open the lid. I'd guess this has happened about four times in as many months. No amount of bowl cleaning eliminates the odor, but the ordor seems to go away as suddenly as it began.
This makes no sense to me. The inside of the upper rim is the only part of the toilet I can't clean, at least not directly. But since the toilet bowl is new and never experienced an overflow, the rim would only have seen clean water! So where is the odor coming from?! I always thought a toilet trap provides absolute protection from sewer gases.
Or is this simply an unavoidable fact of life?
