breaker breaker 911
nicks240
hey all i have a problem with my sprinkler system, i have a rain bird system ran off a shallow pump. the box cycles but when it goes to turn on the pump it throws the breaker and the pump dont even try to turn on, i live in florida and we havent had rain in a while so my grass is looking pretty bad, someone help please.
Do you have a GFI breaker?
If you have a GFI breaker, then you could have a small short from a wet exposed wire, or a neutral touching a ground wire or other ground.
If you are tripping a standard breaker then you have a hard short somewhere.
thanks for the help. also last year the system would come on , but every once and a while it would throw the breaker now, it just wont come on at all, could it be a bad pump?, it looks pretty old
