View Full Version : Bronze/brass vs. plastic shower drain
bmw3034
05-14-2007, 05:48 PM
What are the pros and cons of a plastic (ABS/PVC) drain versus bronze/brass? While both meet code, is there an longevity or durability factor in using brass/bronze? Which do most plumbers prefer?
jadnashua
05-14-2007, 08:29 PM
The moving, visible parts, and those things that control it might better be brass - they'll hold a finish better that plastic. The actual drain line - plastic is probably okay. I did some remodeling at my mother's house over Christmas...the brass tub drain came apart in my hand, the pvc stuff was still good. The softer plastic is more liable to get the finish damaged because the plating is hard, and the plastic is much less so. The differences in thermal expansion means the bond won't be as reliable, either. My personal opinion.
Dunbar Plumbing
05-14-2007, 08:48 PM
I prefer the brass drains for a few reasons:
The plastic holding nuts can crack over time from being under the stress of being tight.
Removal of that nut and reuse is impossible when they leak
Brass however will not stay clean for long iin the conditions it is exposed to.
An all glued PVC drain assembly is a nightmare to remove in close quarters; the brass holding nut can be removed along with the assembly, cleaned and reinstalled if the installer didn't properly bed the base of the unit.
I get about 3 to 4 calls a year where the plastic nut broke and was leaking bad. Less than that I get a call rarely that a brass drain is leaking; most times the base is free floating allowing movement of the drain independent from the fixture.
