Drain pipe overflowing
sparkyrhett
Good morning. I have a Maytag wash machine that I have to stand by during the pumping cycle to turn off when the water gets to the top of the drain pipe. I allow the water to go down then turn the machine back on to finish the cycle. This does not happen all the time but most. Sometimes the water seems to go out at a slower rate, therefore not backing up. The washer is about 4 years old and has its own vent. Any suggestions would be greatly appreciated. Thank you in advance.
There may be a partial blockage in the line somewhere if it was working fine up till now and the line needs to be snaked.
If you have always had the problem it may be the drain line is to small (1.5"). New washer drains are 2" and newer washers have faster pumps which can cause backups on the smaller drains.
You also may have galvanized drain pipe which has become restricted and is in need if snaking.
