GroheDal in-wall toilet carrier install problems
wharf
Virginia
Hi, I have been reading these posts for years, but now I need HELP!
I have read all posts related to in-wall carriers and Duravit products.
I have tried to contact Grohe. I have looked online for days. Has anyone installed one of these??
I have 3 questions:
1. Can I make a 90 degree turn ABOVE the floor with a GroheDal and Duravit Stark 3 bowl?
2. How do I "fix" the water shut-off inside the tank? I am very unclear about the water supply hook-up as the install instructions are in pictures and that part is NOT included.
3. I own 2 and am still need a third. 2 can go straight down through the floor, one needs to make a 90degree turn *backwards* before going down. If GroheDal cannot, then I need to find another carrier/bowl. If so, any suggestions?
Thank You very much in advance!
wharf said:
... make a 90 degree turn ABOVE the floor with a GroheDal ...
Yes.
Twist it, pivot it.
What are you going to do about venting? Before it turns down to go through the floor.
Post a picture of the back of the carrier. Post a link to the PDF file on the web. Call whoever sold them to you and get the 1-800-tech-supprt phone number for these carriers.
Have you read my posts about wall-hung toilets? The Geberit "OEM white label" carrier takes the same bowls. I hung a Duravit on it. In case you wanted to know.
David
I don't think you have enough room to go backwards unless you are going into another room. The center dimension of the pipe going down from the carrier is 3 1/2" and the total depth of the wall is 5 1/2" so you only 2" to play with not much to cennect a elbow inside the wall.
The water shut-off valve is a 3/8" fine thread x 1/2" male ips valve, the 3/8" side is connected by a small hose to the fill valve and the 1/2" side is connected to the water supply, everything can be accesed from the front.
Geberit's carrier has the same connection at the bottom.
if you want to e-mail Duravit you can try Kyle.Seaton@usa.duravit.com or you can call them at 1-888-387-2848.
If you need parts or installation instructions they can e-mail you.
Great Info!
Peanut; we do have room backwards because we had to build out 3 inches into the room with the 2x6 because of an obstruction.
David; I will search out the posts again now; I must have read it since I read all posts. I chose the GroheDal because I liked the plate better ("Surf"). I am not springing for the dual-flush plate, at this time. Which Duravit model bowls have you seen? I have Stark3 which has an ungenerous seat; that is, the rim is very narrow. I want to order another for the kid's bath that may have a smaller opening (so they don't fall through!), though of course, same size outside dimension.
I cannot get pdf's tech specs for the darling SEAT online (nor any Duravit seat..), but am considering it as the seat looks more like standard US.
I will call that contact at Duravit, either way.
