View Full Version : foamy water
Timmy
04-28-2007, 05:18 PM
Today when I turned on the kitchen sink faucet for cold water, what came out was very foamy. When I filled up a glass the foam would dissipate after 5 seconds or so. After letting the water run for about a minute the water was no longer foamy. I tried the faucets in the bathroom with the same results, very foamy. After turning the faucet off the sound coming from the drain was as if I had poured a bottle of carbonated water down the drain. The water is always clear, just foamy. My water comes from a well. What could cause this?
leejosepho
04-28-2007, 06:21 PM
I sometimes get something similar when I change my filters, but I do not know the cause.
Gary Slusser
04-29-2007, 02:59 PM
The usual cause is air. There are a number of possibile causes if you have your own well, but with city water.... do you have a softener or regenerated or backwashed filter? Unless you have a disposable cartride filter and just changed the cartridge.
Cal
04-29-2007, 04:04 PM
I find this happening a lot on the houses that I pipe with cpvc... is that your water distribution pipe ??
