Removing reducer bushing?
Nate R
Milwaukee, WI
I just had a plumber here to look at my plumbing situation. I'm remodeling a bathroom, and want to move the tub and sink drains. Currently, the tub and sink join into the toilet drain as shown below.
I wanted to move the tub and sink to the opposite side of the bathroom. My thought was to abandon the current tub/sink drain and instead join them with a different branch that services something else, but needs to go from 1 1/2" line to 2" to be able to handle it.
Clothes washer, tub and lav would be on one branch. Washer does NOT have a tub, just a standpipe. If I understand what I'm reading, the washer is then 3 DFUs, and the tub and sink are 3. Which would require a 2" horizontal branch instead of the 1 1/2" there now.
Below is a picture of a tap into my stack. If I'm looking at it correctly, there's a 4" stack with a 2" tap on it, which is immediately reduced to a 1 1/2" line. Is there a way to cut out the 1 1/2" line and replace it with a 2" w/o removing the wye from the stack?
If not, I suppose I'll just cut out the PVC below it and add another branch instead.
There is a big reamer that can drill out a fitting. Forget the name right now, but it has been mentioned fairly frequently. Might be cheaper to cut it out and put in a new fitting.
You can buy a Pipe Shredder bit, or a Rambit, but for a one-off, that's pricey. I would cut the bushing flushing with the hub, cut a little slice with a hacksaw blade and peel it out. put a hose clamp around the hub so you don't break the hub. Been there, done that.
Thanks everyone! I was hoping/praying that there'd be something like that.
It may be a bit expensive for a one time use tool. But I'll use it again when I redo the kitchen. (There's another setup right above this one that's identical.)
I also would MUCH rather pay $30 than have to fool around cutting chunks out of the stack. :D
bushing
A Ram-Bit won't work with a bushing because the "hole" in it is smaller than a standard pipe, and a Ram-Bit is sized for the i.d. of a standard pipe.
motosliders said:
So I suppose I could use a dremel and a vacuum cleaner to enlarge the hole to standard pipe ID?
Not within any acceptable tolerance. But, you could substitute the Dremel for the hacksaw blade and try this:
