nigma444
04-23-2007, 01:58 PM
Hi,
I've got a Toto Aquia that's about to be reinstalled after a bathroom remodel. It looks to be a flush to the floor flange situation that I'm installing it on. More or less anyway. It's not PERFECTLY level either, a little bit higher in front than the back. It used to sit up off the floor a bit more, but the remodel raised the floor slightly, so now it's more flush.
So two question. First, the flange and piping I have is all copper stuff. How much can I hammer on that to get the flange level without breaking any seals? Or is that necessary?
Second, am I going to need a flange spacer to get a good seal or will the wax ring still work ok? I also contemplated getting one of those waxless rings with the gasket instead, since it seemed like the flush flange with wax ring sealing issue wouldn't even be an issue. Would that work better or do those have issues with going bad over time? I know the wax ring is tried and true, and I don't want to have to be replacing that other gasket every few years or something, if it's not necessary.
Thanks,
-Josh
Thanks,
-Josh
