I am new to this forum. I have a goulds 1/2 hp submersible pump.static water level 32 ft. below ground surface,pumping level 52 ft., pitless adapter(what ever that is) 20" above ground, pump depth102ft. drop pipe 100 ft. Our home is 17 years old and we have had on going problems.It started with our water shutting off on occasion . I would have to go into our garage and pull up on this metal lever behind a box next to our bladder tank.than our water would come back on.Our water would turn black. It would clear up over night . Than I couldn't run our hose the water would shut off.Now I can't run our washing machine ,the water shuts off. When I try to pull that metal lever it takes a half hour or better to get the water back on and sometimes it shuts right back off.I thought we might replace our blatter tankAny ideas as to what the problem could be?? Thanks!
