View Full Version : "Need Help ASAP", Thank you! Pressure Loop Problem with Moentrol
JZavoda
04-13-2007, 10:52 PM
I have just installed a Moentrol off of a pressure loop which leads to four body spray jets, a rain shower head, and seperate body spray system. The problem I am facing is that upon installing this unit I now have turned on the water main and I am not getting any water through the lines. Could it be possible that a lever is on backward on my Moentrol or that a valve is upside down blocking the flow of the water? Any troubleshooting help would be appreciated. Thank you for your time. Jeff
jadnashua
04-13-2007, 11:27 PM
Some valves have integral service stops...you sure all of them are on? Also, if you only turned on one supply, the pressure balance feature would block flow. You need both hot and cold turned on.
