I noticed the gauge on my holding tank was low though the water pressure throughtout the house seems normal. I recharged the tank by draining and pumping in 28psi ( had been running a 30/50 cycle). Still the gauge only reads about 19 and the new cycle is 14/19. Could this be a bad gauge? I held the contacts on the pressure switch (square d) and after awhile water started pouring out from the pipe underneath the switch it eventually stopped what does this mean? I also notice some bubbles in the filter housing when the water is running and the filter was particularily dirty and full of more sediment than usual. Is any of this related?
