View Full Version : Do you use teflon tape or pipe dope on seats and stems?
Verdeboy
04-11-2007, 11:05 AM
Just wondering. I haven't been using it, but I noticed that the threads on some of the seats and stems I replaced were wrapped in teflon tape.
jimbo
04-11-2007, 06:28 PM
They are not designed to require any sealant on them. I always use teflon tape. I never have leaks, and I am too old a dog to change my ways!
04-11-2007, 07:15 PM
I believe the seats need some sort of sealant, if not paste thread sealant, then maybe Teflon tape.
With the stems, those have washers that seal.
Verdeboy
04-11-2007, 09:46 PM
Follow-up question: If a valve stem or seat was not sealed properly and thus leaks at the threads, would it show up as a leak in the shower or behind the shower?
I'm guessing the valve stem would leak inside the tub in the same way a stem with a loose packing nut would leak. And a seat that is not sealed properly would leak behind the shower (and might do some serious damage). Is this about right?
Winslow
04-11-2007, 11:34 PM
The seat is located inside the valve body. I use pipe dope, not necessarily as a sealant, but to ensure its eay removal when its worn out.
plumber1
04-12-2007, 05:50 AM
A thin wind of thin tape under the seats' shoulder will insure no leak from the back side of the seat and won't interfere with anything. I look at as a gasket.
Same with supplementing the seal where the steam it threaded into the valve body.
