Hello,
I've been reading about diverter issues on this forum but have not seen one like mine, so please accept my thanks in advance for reading and for any advice offered.
My house was built in the 30's and although someone has remodeled the hall bathroom within the last 10 years, I suspect the faucet setup was not replaced. It is a 3 valve bath & shower system that looks rather like http://www.centralbrass.com/documents/specsheets/S0968Z.pdf . I have no idea if that is really it, of couse. When the hot water is turned on with the diverter in the bath mode, (hot) water leaks out the back of the diverter knob. I removed all 3 taps and replaced washers (stem packings) on the hot and cold. The diverter washer was also in bad shape as well as an O ring that essentially disintegrated, and which I've yet to figure out how to replace. The bigger problem tho is that once I removed the stem, it appeared that within the diverter assembly is residual bits of what might be leather. Is this possible and if so, how do I replace or repair this? In addition, putting the hot and cold nobs back together has introduced a new problem - knobs that are now very difficult to turn on and off. Ugh.
Any comments or advice would be most welcome.
Thanks,
tal
Thanks,
tal
