View Full Version : HELP!! Wet stains on ceiling under shower tub
DIY-new
02-09-2005, 04:36 PM
2 days ago we noticed 2 big patches coming up on the ceiling under the bathtup(which is on the 2nd flr) . took the measurements and the patches are forming on the opposite side of the shower drain and not right underneath it. these looks like so called "wet-spots" but i;m not sure.
I don't have much plumbing experience.
appreciate the help.
thanks.
jadnashua
02-09-2005, 07:44 PM
It is not at all uncommon if you have aleak for the water to travel a little bit - to the next joint or whatever, which breaks up the flow and causes it to drip off of the pipe. Sounds like you need to dig into this and figure out what and how this is leaking. If it is old, it could be a corroded pipe, if new, it could be a faulty installation, or defective part. Is there or has there been any water leaking out on the floor? It might be that, and not the plumbing. It could also leak from a bad caulk joint or a broken grout line in the tile. Especially if the tub is not level, water can pool and leak into the wall. The caulk might have failed, and just now start to reveal that fault. Lots of possibilities. If there aren't any visible grout or caulk problems, you'll probably have to tear out part of the ceiling and take a look to see what's happening. Note, I'm not a pro.
jdkimes
02-10-2005, 09:12 AM
You might as well cut that ceiling open to help find the source of the problem anyway since you'll need to remove the wet/damaged pieces to fix it properly.
DIY-new
02-10-2005, 10:37 AM
thx for the replies guys..
I don't see any standing water on the bathroom floor.
also no clauking problems.
looks like i'll have to cut open the ceiling to see what's going on
thx.
