View Full Version : Water heater door question
Bigbobdallas
03-25-2007, 05:54 AM
I had a gas heater now have electric. Now the question is as far as replacing the door does electric have to have loover in the door or can it be a solid front door. Hope this makes since the question that is
Dunbar Plumbing
03-25-2007, 06:20 AM
If there is a gas furnace in that same room, YES, you will have to leave them in.
Some buildings are built with a fresh air return to allow this makeup air to travel into the room. Otherwise the louvered door or extremely large gap between the door and floor is practiced.
leejosepho
Since the gas heater needed air for exhaust venting and the electric heater does not, I would say a solid door should be fine as long as that would not block/stop the air needed by the furnace for its own exhaust venting.
Bigbobdallas
03-25-2007, 07:27 AM
We have no gas any more it is turned off outside and everything is now total electric. What venting are you talking about in electric
Electric appliances, other than most cooktops, do not need venting.
