paperprofit
03-24-2007, 09:31 PM
I cut holes in my kitchen soffit :( to determine the source of a very minimal water leak and discovered the joint of the ABS closet flange and the 3" diam. Schedule 40 waste pipe is leaking. (You can see a photo here
http://farm1.static.flickr.com/181/435871637_e67b9baaac_m.jpg (http://www.flickr.com/photos/7539296@N06/435871637/)
...which shows the mineral build up at that joint, visually confirming the point of the leak... where the closet flange joins to the waste pipe.)
Does anyone make a wax ring with an extra deep funnel that might get me down past the joint?
Or should I try to (carefully) pry out the closet flange (from above, after removing the toilet)? If it comes out, is it possible to clean the waste pipe enough to cement on a new closet flange (maybe one that is deeper?)? If so, should I replace it with another ABS closet flange?
Or should I just cut the waste pipe in the middle, leaving a 1" long stub (there's only 2" of pipe connecting the closet flange and a 45 degree elbow directly below), add a coupling and cement everything back together? (Is 1" of waste pipe even long enough to make a proper cement joint?)
Thanks for any and all suggestions!
