rmack
02-08-2005, 05:15 PM
We recently moved into a new house where we had requested the plumber use Toto toilets. We have several Drake CST744S toilets that have leaks between the tank and bowl. Water will drip off one of the tank bolts after the units are flushed several times. The plumbers discarded the installation manuals so I have nothing to reference if the install was done properly. I loosened two of the tanks and tried to center the foam ring hoping that it would stop the leaks. One seems to have stopped, but the other is still at it. The bolts have rubber washers. I can't figure this one out. In the past I have rebuilt several old toilets and never had this problem. It seems like the foam ring used between the tank and bowl is not closed cell foam. I should not have to spread some type of sealer on that connection. Friction and compression should be adequate. Any idea what is wrong? Thanks for any help.
