toredo
03-22-2007, 12:38 AM
The frost free hose bib recently burst from freezing, allowing water to flow into the wall, downstairs bedroom and bath room. There was no stop cock inside the house. The house is two levels, built on a quite steep incline running down from the front of the house to the back; both levels being on ground level. The hose bib is on a side wall toward the back of the house and is extremely inconvenient as there are only loose stones on the slope at the side of the house.
To overcome the difficulty in accessing the hose bib I ran a PVC pipe from the bib up the hill to the front of the house and installed a faucet and hose connection at the top of the incline. The PVC pipe ran down to a tee at ground level directly below the bib. From one side of the tee I ran the PVC up the hill, in the other side of the tee I installed a faucet for the purpose of draining the system. These changes were made about eight years ago and have worked, until this winter, without problem.
My normal practice for winter is to turn off the hose bib, open the hose outlet, open the upper hose faucet, open the faucet at the tee and drain the system. This year our winter temperature hit lower than in previous years and the frost free hose bib froze and burst. It is my belief that the angle at which the hose bib pipe was originally installed sloped up from inside the wall to outside and that some water did not drain from the bib. The bib was equipped with an pressure equalizer. A stop cock has now been installed, along with a new bib, and I will now be able to open the hose bib, along with the aforementioned faucets, when winterizing.
My question is; does the system I have described sound as though it will be safe from bursting in the future? Does the fact that I have a PVC pipe connected to the hose bib increase the chances of the bib freezing and bursting?
Toredo
Toredo
