gplumb
I just put in a hot water recirculation system with a return line to the water heater where the pump is located. It works great! I want to insulate both the hot supply and return lines in the recirculation loop (about 210 feet). I have seen several types of insulation ,i.e.,rigid foam and the flexible rubber type which is much more expensive. I plan to use the one that has the removable tape seal. What wall thickness is suitable? Home depot and Lowes seem to have the 1/2" wall, but my plumber says to use the thickest wall (1"). The 1" is more costly and I have to go to the plumbing supply house to get it. Also is the R value of the rubber that much better than the foam type? And would the difference in cost make it cost-effective?
