View Full Version : Granite support for island
HoneySuckle
03-10-2007, 10:34 PM
I had three wooden corbels made up for my island overhang but think they look very old fashioned and my kitchen has a modern look. Our granite install is not due for another two weeks so what can I use in place of these wooden corbels? I really don't like them:o My island will have approximately 12" overhang and the installer says he will not install anything with an overhang that is more than 6".
Mikey
03-11-2007, 04:58 AM
I googled {modern corbels} and got about 95,000 hits, the first few of which were manufacturers of the things in a gazillion styles. If none of these work for you, you could just let simple cantilever beams into the top of the island. They could be made of wood, or a more "modern" looking material like stainless steel. A standard shape (box beam, I-beam, etc.) wouldn't be terribly expensive, but a good shop could come up with anything you'd like.
geniescience
03-11-2007, 07:15 AM
have you had a talk with the kids and with the installer, about how much weight the stone will take before cracking?
IKEA sells triangular braces (i guess they're corbels), that look clean and modern.
david
HoneySuckle
03-11-2007, 09:05 AM
david
We don't have an IKEA and it would take too long to reach me. Someone had suggested them as well.
Mikey I also googled and found a few but nothing I liked. Do you think fabricators sell these things? Are braces attached the same way as wooden/metal corbels?
Bob NH
03-11-2007, 11:35 AM
You will have adequate support for the granite if you put a number of 2x8's extending outward from the base, with the length of the 2x8's running transverse to the top of the countertop. Ideally, they can extend across the full countertop and be supported on both sides. If that is not possible, they can extend equal distance on either side of the edge supporting the 12" overhang. The granite can be supported on the outside ends and the inside ends of the 2x8's.
The ends of the 2x8's can be covered with some kind of trim, and are probably invisible because they are so far under the edge.
The 2x8s can be spaced about 16 to 24 inches. The granite can be supported using a flexible adhesive.
Another solution if height is available is to install a glued-together double thickness of 3/4 plywood or OSB extending out far enough to support the granite.
toolaholic
03-11-2007, 12:31 PM
Used 3/8" x4" steel flat stock. steel holes counter for screws. Son did this prep for granite installers. He has all the specs. If you need them ,let Me know
toolaholic
03-11-2007, 12:34 PM
can't believe You 're guy doesn't know this! How much experiance does He have?
HoneySuckle
03-11-2007, 01:10 PM
Yes, I would love the specs please. Basically the fabricator said I had to get the support for my granite top.
Bob, who would do those 2 x 8s? :confused:
toolaholic
03-12-2007, 06:42 AM
will post specs. tonight, Honey. This is the way to go. been at this 45 yrs so far!
The granite guy is not going to suggest anything, because if the granite cracks he would be responsible if you used his suggestion.
I would, and have used, either 3/8 flat, or 1 to 1.5 inch angle iron. The application of either is going to depend on the cabinets you have, how they can be supported, and where the brackets have to be attached.
My last installation used 1X1 angle iron with plates welded to it allow them to be bolted to the side panels of the cabinets. The faces of the cabinets had to be cut out to allow for the iron. They were supporting a 19 inch overhang.
I agree, fabricators do not want to take the responsibility of making recommendations.
Keep in mind that one SF of 3cm granite is about 20 pounds, plus kids, people leaning on it, etc.
Bob NH
03-12-2007, 11:59 AM
Any carpenter, or the cabinet installer, can install 2x8's or a deck or 3/8" thick steel plates on top of the frame of the cabinet. I would put something in to span the front-to-back of the cabinet and extend enough to provide support within 6" of the edge of the granite.
I'm surprised that the granite installer hasn't provided you with a plan for what is considered acceptable.
toolaholic
03-12-2007, 07:49 PM
By the way this is around a 4 1/2 Mill. home set on 2 1/2 acres in Tiberon ca. with a view on the G G bridge. My son used 1/2" x2" steel flat stock. the overhang is 13" steel sets in 6" from each end of 8' counter and are placed 24" on center. plywood substrate is 3/4" Brian routed out 1/2" grooves into the ply top. counter is rock solid. Neat detail no angle iron leg exposed. good luck
HoneySuckle
03-14-2007, 09:57 PM
They only advised that we have some type of support saying that what we choose is personal. Probably don't want to have any problems down the line. Our granite is 2 cm. I even asked about plywood and they don't use this. The granite goes directly over island and cabinets. Is this normal procedure?:confused:
geniescience
03-15-2007, 09:28 AM
here may be where you need a handyman who really feels comfortable with the concept of "strength" in supports. Someone who is comfortable with metal and wood.
Any support will work.
Personally I would feel comfortable with buying cold-rolled soft steel tubes (either 1/2"x1" or 1/2"x1.5") with 0.065mm thickness walls (that's 1/16th" thick) and building them (welding them) into a support that sticks out 11". Looking at it from underneath, it would look like the letter "E" with the outside corners cut at 45 degree angles. The three prongs continue and go inside (if possible) the kitchen island, or if not possible, then the two outside ones continue underneath the granite, but outside the kitchen island cabinet, and keep going to the end, just to keep visual continuity. If you have no idea what all this means, find someone who has a few welding machines in his basement, and ssk him what argon is. Ideally, this kind of handyman -- who owns welding machines -- is someone who likes a cute and beautiful little project. Cost is $100 approx.
David
toolaholic
03-15-2007, 07:04 PM
I have been in the trades for 45 years. Ex pile buck. WE can build our own cabinets. I gave You GOOD INFO. This guy isn't putting down a 3/4" plywood base? Where did You find this Guy? Your in TROUBLE! good luck
geniescience
03-15-2007, 09:27 PM
FWIW, there are people installing granite now with no ply under.
Recently I saw a 2cm thick countertop that stuck out 24" -- bare and unsupported -- and it was finally supported on one leg centered near the end. Nothing else. Obviously nobody is ever going to get up on it, because it looks too flimsy.
Honey, getting back to your case: I saw you asked near the begining "Do you think fabricators sell these things? Are braces attached the same way as wooden/metal corbels?"
Just to be sure we are helping you, I'll generalize your requirement. Here goes: any triangle is a brace (a corbel is a brace), and any two screws, one at each end, will hold the (triangular) brace in place, strong enough to do the job necessary. It's the triangle that does the job. It just happens that steel and some other metals are so strong that the triangle can become almost invisible to "you", since its shape looks more like a stick sticking out than a formal triangle. The three points of the triangle are still there, but flattened into a 1" or 2" bar or tube or "flat stock".
Any support will work. Any triangle, whether it looks like an empty triangle or not, whether a bar, tube, wood beam or whatever.
Your distance to support is short.
Your kids may promise never to sit on it or stress it with sudden shocks, blows and bumps, in which case you could leave it unsupported. Ha.
david
toolaholic
03-16-2007, 07:44 AM
We use 5/8" +ply sorry 6" no sweat.
HoneySuckle
03-20-2007, 11:29 AM
With a deadline to work towards, we had to install some type of brackets and my husband was able to find some shelf brackets at Lowes. We bought three of them and the installer pressed as hard as he could (he was a biggie) and it didn't budge so we're hoping that this is all the support we will need. Luckily we only have 2cm granite if that makes a difference. Thanks for helping out. Will at least be able to use your ides for my brother's remodel:)
