30 inch flare Faucet supply tube
Ddagsyn
Texas
I am trying to find a 30 inches -3/8" FLARE to a 1/2 FIP Faucet stainless steel braided supply tube to go from my shutoff valve to my Kitchen faucet. I have tried HD but all they sell is the 12 inch size.
Could someone post a website that sells this size.
Thanks
Flare lines are not so common, 30" may be hard to find, but here's an easy fix:
Take the 12" one you did find, connect it to your valve, then use a brass 1/2" close nipple to add on a 16 or 24 inch long FIP x FIP line. This is a very common line and readily available.
Do they make a flare to compression nut i can screw on the stop valve on the flare end and attach a 3/8 " compression to 1/2" FIP braided stainless steel connector. if so what is it called
Thanks
Well, they do make all kinds of adapters, but this would not be common. I have never seen one. I still say join 2 hoses with a nipple.
Thanks all, I did find a 30 inch 3/8 flare to 1/2" FIP braided stainless faucet connector made by Flow master at a plumbing store.
