SVWillow
03-05-2007, 09:30 PM
Center line of drain stub is 17 1/2 " below bottom of counter top. Using a 9" deep undermount SS sink and a 444 Insinkerator disposal, the center line of the disposal outlet will be about 16 1/2" below the bottom of counter top. Attached to the disposal outlet would be the tail pipe, the length of which, from centerline of disposal outlet to bottom of tail pipe, is another 4". I assume you would then attach the trap and come back up to the drain stub.
Link for spec sheet for the 444 Insinkerator showing demensions:
http://www.insinkerator.com/pdf/H536.pdf
Disposal was existing, but haven't purchased the sink yet. Do you think a 9" undermount will fit, or will the disposal outlet be too low?
Thanks for any help
Thanks for any help
