JCH
Ultramax toilet continues to block frequently in "real world" use (so to speak).
However, I can flush fairly large amounts of plain toilet paper down without a problem. (10 wads x 24" of Charmin UltraSoft).
This makes me think that there are no obstructions. (Used a mirror to check the trap; dumped 10 gallons of water into system and it flowed no problems).
However, with a "solid" load, it will often block.
I had the toilet off yesterday and noticed that the 90-degree bend right below the flange seems like a tight turn. I'm wondering whether the solids can't make such a sudden turn without, um, piling up and blocking...
Do they usually use a larger radius bend directly under the toilet flange? Or are 90-degree ABS pipe fittings only available in one radius?
.../j
.../j
