PVC pipe labeled DWV vs Drinking
Jake_homeowner
Virginia
I am setting up a chlorine injection system and retention tank and the 1 1/4 inch PVC pipe I purchased at the local hardware store is labeled DWV. The 1 1/4 pipe only needs to run about 2 feet between the injection tank and the retention tank. Does it matter that its not labeled Drinking like the rest of my 1" PVC supply pipe or is just labeling. This is on a well system running between 40-60 PSI.
Thanks,
Jake
DWV pipe is not rated for pressure and will rupture if subjected to it.
In the case of PVC, Co-Extruded DWV pipe has a foam core and only 2 thin layers of solid PVC - inner and outer...
