Sleepdoc
I live in the virgin Islands and my home uses cisterns (we catch our own rain water). I have a simple bladder pressure tank and a 1.5HP pump with a pumptrol square-D attached to it. I have the tank set to 28PSI with a 30 PSI "kick on" and a 50 PSI kick off. So all this stuff should be set correctly
Recently, i found out that my bladder pressure in the tank was low. the syptom that lead to the investigation was the on/off cycling of the pump at the end of its repressure cycle.
Now that I added the pressure, i have a new problem....
The Pumptrol gets stuck and does not turn on when it is supposed to. so sometimes, our water pressure drops to a trickle but the pumptrol still doesnt kick in. Oddly, all i need to do in order to get it to kick on is to tap the pumptrol-D lightly with my knuckle.
Why is is sticking? Can i adjust this in my favor by doing something like turning those screws that have springs attached to them? clearly, this is some sort of mechanical balancing act that is not playing out at the end of the pressure cycle correctly
Can anyone guide me to a document that describes how to use / adjust those springs? Or better yet, just tell me exactly why it is sticking at the end of the pressure cycle and how to make it work correctly?
Thanks,
Glenn
Thanks,
Glenn
