Turbo Torch
Jeff lange
http://www.thermadyne.com/turbotorch/literature/pdfs/Page6.pdf
Where to buy
I am looking to get a torch like the pros and came across this one and wanted to know if itwas any good? How much do they go for?
Thanks
Jeff
Unless you're in the business of using a torch quite a bit, I dont see the need for a B tank, but hey...that is one man's opinion. Like Rugged, it is what I use, but only for commercial plumbing (my "regular" job)....which is 95% of the time. For working on my own on residential projects, I just use a small MAPP gas setup. Works great and I'm not lugging that big tank around the customer's house. If you're dead set on a Turbo Torch, but you wont be using it frequently, check into the same setup, but with the small tank and regulator (MC). Its alot less cumbersome.
It's all I use - B tank and Turbo Torch - good for soldering all sizes of pipe up to 5" copper and brazing up to 2.5"...
turbo torches
that top set up is all you really need.....
the LARGE B tanks are a pain in the butt and weigh too much
for average service work.....they are best for heavy
construction jobs only..... my opinion only
dragging a B tank across a tight crawl space
getting it covered in mud, then going to the next call and
laying it down on a ladies kitchen floor with gravel
still stuck to the bottom of it does not go over too good.....
or hauling one down a flight of stairs gets very old
after a while....
they get very, very heavy by the end of the day
I have that top set up with the larger torch tips...
and its been adapted down to the smaller " mc tanks." ...
it has less volume, but its a fourth the weight and
worth the trade off
I carry 2 extra mc tanks with me for a back up.
I use a small map torch too ..all i need.. unless you work on 4 inch mains all the time. its overkill. my setup fits in my toolbox
