City water is presumed safe so doesn't need a filter in that sense.
Odor and taste can usually be taken care of with an activated carbon filter. The levels are generally low so the filters last quite a while, if you start with a large enough unit.
Carbon filters are usually preceded by a 5 micron dirt filter so the carbon filter won't get plugged up before the carbon is depleted. Sometimes the dirt filter is made part of the carbon filter unit.
If you are using it only for taste, you could put a 10" cartridge under the sink. If you want a larger filter that you can put somewhere to treat all of your water, you can do that also.
Harmsco makes cartridge filters and housings. You can put your own system together.
When you decide what you want, I can suggest a filter.
The galvanized pipes are 30 years old. I'm not seeing rust stains yet, but I know it's coming.
From prior experience, I know galvanized pipes sluff lime or calcium. In my opinion, the water is hard. Galvanized pipes in this area tend to loose flow as time goes on.
I don't plan to do the whole house, just the drinking water at the sink.
Also, I've tried other twin cartridge units before, and never knew when to change them - the flow rates never changed much, it was always slow.
