Where find PVC S&D pipe?
wayne Ateser
Orange County, CA
Im looking for 6" ASTM D2729 PVC Pipe. Its a thin walled, non perforated sewer and drain pipe.
I have called dozens of suppliers in Orange County, Ca and even a manufacturer and none carry it. The manufacturer said that dont make it any more.
Any thoughts on where I can find this pipe.? I have found 4" dia at Lowes but really need the larger dia pipe.
thanks for any tips
If you are passing through Southern Utah... My supplier has it in 4" to 8" in stock including fittings... Probably doesn't help you tho.:o Also has X-PVC from 1-1/2" to 8". Man... that's gotta be a bear to cement together!!!:eek:
OK XPVC is the same as the DWV PVC (Sch40) I was talking about then...
8" is not actually bad - bevel the edges of the pipe and use lots of glue...
