View Full Version : Cut & Jack Hammer Basement Slab
Dan Pick
02-18-2007, 11:42 AM
In my basement I need to cut and jack hammer about 10' of 4" concrete slab to replace 50 year old CI drain pipe. It is all gray water from the kitchen and laundry that comes over to the drain pit under the basement bath tub. In the process of converting/remodeling basement bath I removed old enamaled steel tub. This is when I noticed black pea gravel and foul musty smell from leaking/broken drain line. The connection at the bath tub drain was a banded coupling to black ABS drain pipe (ABS must have been added later after initial house construction since I can see where the floor has been cut and patched before).
My questions:
Rent diamond saw and electric jack hammer?
Could I just use a diamond blade in a portable circular saw?
Build a tent to encapsulate dust from both operations?
Score concrete or cut it all the way through completely?
Use PVC pipe or continue with ABS?
I don't see ABS pipe at the "Big Box" stores, any reason?
Thanks, Dan
master plumber mark
02-18-2007, 11:48 AM
saw cutting that floor makes one a hell of a mess.....
the tent is a great idea.....but you got to breathe too..
also having someone saw cut the floor for you
is not as expensive
as you might think...
and having them cut it all the way through
is always best....
I would make sure that their are no surprizes
in the concrete that might get you shocked,
the sch40 pvc is what is supposed to be used in the
slab floors...
it all brings back fond memories
that I would rather forget.
Dan Pick
02-18-2007, 12:02 PM
Thanks Mark,
Do you recommend anyone in the Indy area to cut and jack hammer the floor?
02-18-2007, 12:23 PM
I would find a contractor that uses a "wet saw"
No dust
Clean cuts
Less noise
The ones I use have all the hand and power tools too.
They have me work the wet vac, while they cut.
geniescience
02-18-2007, 12:40 PM
i wish every cut i ever made was with a wet saw.
The dust is bad, when dry cut. Dangerous little particles that float everywhere. No tent will hold them in.
david
master plumber mark
02-18-2007, 12:47 PM
I was not aware you were from Indy....
I have gotten away with bloody murder before with
CAPITOL CONCRETE ......
they did great jobs for me back in my
more commercial days....
look in the yellow pages..
and dont be ashamed to ask them what they will tear
it out and carry it all away for you would cost.......
its not that much ....
Gary Swart
02-18-2007, 01:38 PM
It sounds like ABS is not permitted in some localities, but it is OK in others. If it's not available in your area, it probably because local codes don't allow it. Just use Schedule 80 PVC. I've broken out concrete in my basement and it is not a job I'd do again. Concrete dust get into everything including your lungs. Hire the pros for this. If you were outside, it might not be so bad.
02-19-2007, 04:52 AM
Whether an area has ABS or PVC depends on the preference of the plumbing contractors. If they prefer and use one or the other, that is what the stores will start to carry and concentrate on. Here you have to hunt very diligently to find any kind of PVC drain pipe and fittings.
TedL
02-19-2007, 05:33 AM
Interesting variation. My last house (built 1981) and my current (built 1984) were plumbed with ABS dwv, but I can't find it locally anymore. I was trying to get a trap I could solvent weld directly to the existing, but settled for a Proflex connection.
When I looked at Charlotte Pipe's list prices, ABS was roughly 1/3 more expensive than PVC. That, with ABS's tendency to age less well than PVC, makes PVC a no-brainer for new installations if local code allows both.
I do wish the local suppliers would stock small quantities of common ABS fittings for repair work.
prashster
02-19-2007, 06:18 AM
I used an electric jackhammer and a dry diamond blade saw and a tent.
Problem with wet saws is they're gas powered, so yr not supposed to use in basement without ventilation. (Edit: I was unable to find a rentable electric wet saw)
The dust was so bad in my tent, I could only cut 4" at a time before I couldn't see. Would have to wait for the 'dust to settle' and then carry on. Plus, a little leaked out, and got ALL OVER THE rest of the house. Concrete dust is the nastiest stuff. I think I could hear it laughing in my ducts for hours after.
I scored and then then broke the rest with a demo hammer. One hell of a workout.
I couldn't find anyone to come and do the concrete work at a reasonable price.
If I had to do it again, I'd:
1) Rent a gas powered, walk-behind, wet diamond blade saw.
2) Rent an industrial sized air mover and mount it to my basement window to blow out. Open all the windows in the basement. Probably overkill, but I'd work a few mins at a time, to minimize CO build up.
3) Rent the Bosch yellow jack hammer.
geniescience
02-19-2007, 06:35 AM
electric wet saws come with a long cord so you can get 20 amps from the kitchen range.
02-19-2007, 09:37 AM
Most places have electric wet saws. The Dryer or the range is a good place to plug in.
With a wet saw, there is no dust.
You aren't pounding away at the concrete either.
When I had to have concrete cut in supermarkets, we could cut about 80 feet of trench in a few hours.
We stacked the concrete in the parking lot with a "free" sign, and it would be gone before the day was over.
markts30
02-19-2007, 02:25 PM
For small stuff (home jobs), I have used a regular circular saw with a diamond blade and a pump sprayer (like for lawn spray).
No dust, very quick, easy cleanup, 120V power requirement.
Only drawback - you have to be on your knees to do the cutting and have a wet-vac to clean up the slurry as you go (every couple feet)...
Dan Pick
02-19-2007, 07:35 PM
Thanks for all the great advice, guys!
I decided to have a few "Concrete Cutting Contractors" give me an estimate this week. Two of the local contractors can do the whole job. Diamond wet cutting, concrete removal, and repour concrete after I replace the drain line.
I'll keep you posted on the estimates for 11 feet of 12 wide trench in 4 inch slab. I assume a 12" wide trench is adequate for removal of a 2" CI drain line and installation of 2" PVC line?
I think these estimates will be my deciding factor as to wether I rent equipment and do it myself or hire it done.
Dan Pick
02-19-2007, 07:37 PM
Thanks for the laugh! I was almost in tears telling about cutting inside the tent, and when I started I thought this was the perfect solution to dust....
EAP
02-21-2007, 01:28 PM
12" is plenty of width for your project.
If you do DIY, make sure any HVAC is shut OFF. The dust will kill the blower motor in short order. Better yet, isolate the furnace from the area to be cut if possible.
Unless you rent an industrial wetsaw, this will likely end up being a two person job to keep things like dust under control.
Good luck.
clifforddog1
02-21-2007, 03:44 PM
I just broke up my basement floor today, with electric jack hammer, it broke up easily and way less dust than a stone saw. I own a stone saw and wouldn't think of running it inside, there would be a ton of dust. :eek: I use a full gas/dust mask outside.
John
dgreen1069
02-21-2007, 06:29 PM
I was going to say the same thing....why not skip the cutting and just use an electric jack hammer. Once you get a hole going it is very easy to take it any direction you want. A wet saw inside a house is going to make a big mess also. I'd skip the sawing all together.
02-21-2007, 08:25 PM
The wet sawing I've been a part of has been the cleanest way to go.
It's done with a wet vac, and it is "very" clean.
You can rent a elec jack hammer too, it will have some dust, it will pound the nearby concrete, thereby weaking it some, and will leave rough edges that are hard to pour too.
If it's my job, it's going to be a wet saw and vac.
prashster
02-22-2007, 08:09 AM
I'd use both. You risk overbreaking the slab if you just jack.
If you just cut, you still have to break down the pieces so you can transport them out. A sledge or demo hammer are cheaper than a jack but will give you an upperbody workout.
Personally, think it's worth it to bust up the concrete into small enough pieces that can be used as aggregate filler in the trench once your pipes are laid. It'll save you many bags of concrete, minimizes waste, and minimizes trips up the stairs hauling 5g buckets of rock.
I was surprised at the volume of rock. Felt like I was in 5000BC Egypt building a pyramid for a pharoh (read, wife)
TedL
02-22-2007, 08:18 AM
For those who will not be swayed from dry cutting in a "tent"...
Running a shop vac (with fine particles disposable bag installed) with the hose inside the tent and exhaust outside it will help control dust spread by creating an air pressure differential....
I'd still go with wet.
EAP
02-22-2007, 11:15 AM
Keep in mind no matter how it's done - in a basement with no walk-out, it's gonna be a real workout. In many ways. The cart, jackhammer and bits alone weigh close to a hundred pounds. Lugging that down 15 steps or so is just the beginning and then it's the end and a heavy one at that!:eek:
The amount of rubble left over is staggering to first-timers. Often, you can dump it in the crawl space or at least some it. I prefer to use clean gravel when closing the trench.
As someone else noted, the first cut with a diamond saw will give a clean break at least on the top where it counts.
One other tip, you might find that the slab varies in depth. Usually due to slope towards a floor drain. The farther from the drain, often the thickest part of the concrete. And the most work!
Have fun!;)
Dan Pick
02-23-2007, 07:56 PM
Had 2 local contractors in this week for estimates. They both planned on wet cutting and cross cutting in lieu of a jack hammer. They both quoted to diamond cut wet, cross cut, remove debris and repour after new pipe was installed. There estimates were for an 12" wide by 11' trench and cleaning up the edges of the drain pit was $600.00 and $943.00. I'll keep you posted and hopefully have a few pics to post soon.
EAP
02-26-2007, 02:51 PM
That sounds about par.
If you realy don't want to DIY something, this would be a good one to have the pros handle.
Your back will love you for it!:D
Good luck.
