Andrew M
- Messages
- 31
- Reaction score
- 0
- Points
- 0
Help!!! I am new to this so please bear with me. I am converting a bedroom to an ensuite master in a 50 year old bungalow. Have removed floor, sistered joists, put down 3/4 ply. Ordered a vichy 5555. Wife wants it 5 inches higher than it will be by resting on floor. I will be building a deck around it and tiling. Question is,,,,how can I raise the height of the subfloor under the tub this much? That would be about 10 sheets of 1/2 ply. Supporting sides is not an issue as I can build the deck to height. Second question is, manufacturer recomends morter bed covered by poly. What mix of morter should I use, how much and how and where do I place it? Last question is if there is a way to raise the subfloor, does this cause plumbing problems with the drain? I won't bore you with my custom shower questions yet. (more to come)
Thanks
Thanks
